reinita
Jul 06, 2013Explorer
snowdance wrote:
General things to check. If hooked to a sewer be sure you drain hose has a dip near the end so it stays full of water to keep the sewer gases from the RV Park/city from using your rig as a vent. Also use your tanks and open your valves to drain only when needed and then close again. Do not leave them open all the time. See if the problem goes away.. Also look for a RV park sewer vent stand pipe near your site. You may find one thats the problem..
Fill every sink and shower drain with water so the P trap works to keep gases from coming in.
Under your sink some place you will find a pipe that just ends and has a screw on thing on the top. It has a rubber flapper in side so when you open the tank to drain it pulls air in. Yours may have a problem. You can get them at most hardware/ RV stores. They are just screw on screw off..
Not hooked up to sewer. The valve is closed. No sewer vent pipes found.
Filled all sinks with some water, plus the tub and let drain.
Found the pipe piece thanks to gboop's link. I took it off and put it back on. Can't tell if there's anything wrong with it but p-ew, it certainly reproduced the bedroom smell in the bathroom.
Anything else? We are keeping the bedroom window open for now. But when I did that last night, we got swarmed by a ton of flying bugs that somehow got in. That was fun. ;)
Keep your ideas coming, please!
38,768 PostsLatest Activity: Jan 26, 2021
