WI_Bowhunter
Jul 06, 2013Explorer
reinita wrote:
Found the pipe piece thanks to gboop's link. I took it off and put it back on. Can't tell if there's anything wrong with it but p-ew, it certainly reproduced the bedroom smell in the bathroom.
Anything else?
There may be another one under the kitchen sink. This is where mine went bad. When I took mine off, it wasn't possible to tell if it was bad or not...I just replaced it and it took care of the odor. If this is the problem, the odor is coming from your gray tank. I now treat my grey holding tank with the same chemical as in my black tank. I just buy store brand treatments. You could try to get some grey tank or black tank deodorizer down your drains and into the tank and see if that helps. I would change out any of these valves...around $5 at hardware stores.(bring a sample along to the store) If that does not solve the problem, you will know the old valves were good and save as spares.
38,768 PostsLatest Activity: Jan 26, 2021
