texan21 wrote:
indyzmike wrote:
I wonder if the air units are short cycling. If the thermostat tells the compressor to shut off, and then turn back on too soon, it could trip an overload in the air unit. The compressor should stay off for a few minutes to allow the internal Freon pressure to drop. The outside temperature, and driving, can make a difference in cycle time. If they are cycling too fast, you should be able to increase the differential of the thermostat.
Should I be turning them to "on" instead of "auto" in order to avoid that?
I don't think that would make a difference, they are controlled by the thermostat in both settings.
The next time that the air units kick out, shut them off, wait a few mins, and restart them. Put the thermostats to the coldest temperature possible so that they run continuous. See if that works. There is a possibility of icing when running continuous.
