Executive45
Aug 22, 2014Explorer III
Each faucet has a small screen at the faucet end. Those get plugged with debris over time. That's what Sadie was talking about. Unscrew them and check em....if you haven't already done so, where you attach the hose from the hose bib, there's a small screen there also. After you remove that screen, check the one way valve there to ensure it's functioning. Take a small screwdriver or similar and push in on the valve. It's spring loaded so you might get some water spit back at you...no biggie. Make sure that valve moves in and out. It's designed to allow water to flow in but not out. If the valve is stuck, it won't allow it to open completely and your water flow will suffer. Finally, check your water FILTERS. A dirty filter will lessen water flow.... Let us know what you find....Dennis
38,705 PostsLatest Activity: Jan 21, 2025
