allbrandauto
May 05, 2016Explorer
you say to rich what are the numbers is it a tail pipe test. do you know somebody that has a scanner so you can see data on bank 1 and bank 2 look for fuel trim levels should be around 0 plus or mineus 3 if one bank is off that's wear your problem is sometimes o2 sensers can be bad and not throw a code
38,763 PostsLatest Activity: Dec 05, 2025
