allbrandauto
May 06, 2016Explorer
ArchHoagland wrote:
You need to clean your MAF. The Mass Air Flow sensor determines the air to fuel mixture and, when dirty, will cause Check Engine Lights,etc.
It is located right after the air filter, which should be changed at the same time.
Use MAF spray cleaner, about $10.
38,763 PostsLatest Activity: Dec 05, 2025
