mpierce
Dec 24, 2016Explorer
K Charles wrote:
If you pack the outside bearing the gear oil will not flow to the inside bearing.
1. If you put some grease on the outer, why would you NOT do the same to the inner?
2. The oil will eat away the grease very quickly.
3. :packing" may be the wrong term here. Usually just some grease, to be sure the bearing is lubed right away. Not packed, like one would do on a grease only bearing.
38,709 PostsLatest Activity: Mar 12, 2025
