Matt_Colie
Jun 21, 2016Explorer II
Nobody can tell you very much without close inspection.
While the price seems reasonable, it is 24yo and will soon need some attention. None of this is very expensive unless you don't do it. You can probably do it all yourself.
The tires may look good, but did you check the date codes?
When were the brakes last checked and the system flushed?
All the rubber should be suspect.
Is there ANY evidence of roof leakage. I believe that these have an aluminum skin on a wood frame. Any water leakage can do severe damage before it is even found.
Look it over real hard, it may be a good deal.
Matt
Matt
38,766 PostsLatest Activity: Jan 10, 2026
