AJR
Feb 23, 2016Explorer
Rent one and see how it goes. Even if it is just for a weekend.
Reading here you see all the manufacturers put out a dud every now and then. Some even have layouts that prevent bathroom or bedroom use when the slides are in. In your reading you will get pros and cons on everything from roofs to plumbing.
I had what I consider to be one of the best built TT, an Artic Fox. I moved up to a used gas 36’ class A by Thor, did not like one door for entry. Now I have a used 28’ class C by Thor and really like it. The interior construction is not much different than my old Artic Fox.
Buy used, in fact, look hard at used rental units. Take a peek at irv2.com.
38,766 PostsLatest Activity: Jan 10, 2026
