They are not equivalent Cs of different years. The Access is almost two steps down, as Winnebago positions them, from a MinnieWinnie. There are some differences in construction as well as trim and furnishings.
Minnie Winnie/SunDancer is a higher trim and feature line than Access/Impulse, and will have a basement (6-10 inches between chassis rails and bottom of house floor). The fresh water tank and lines run inside enclosed, heated space, and has larger storage bins because of the higher floor. Thus more cold weather ready. Indeed, it could have dual pane windows, they were an option at that level, but not at the Access level.
MinnieWinnie/Sundancer will have steel spring seating in places Access/Impulse uses foam cushions, higher grade bedding, and a more versatile convertible sofa.
Disadvantages of the greater basement space are a higher step up from cab to house, and greater height overall, for more frontal area.
Access might also have this basement space if the floorplan requires it for the slideout mechanism, but utilities will not be enclosed to same extent, and there will likely be plumbing running outside heated space. This is also floorplan dependant.
If you pay attention to construction details, you will see that the Minnie Winnie/SunDancer is capped where the roof meets the overhead, and at the rear wall. So were the former entry level Minnie/Spirit, but when the Access/Impulse was introduced with lower cost construction features, the Minnie got renamed Outlook, Outlook/Spirit became top of line, and premium models MinnieWinnie and Sundancer disappeared.
In Alaska, if I could find a nice MinnieWinnie or Sundancer at a fair price, I would go for it, because Winnebago no longer builds Cs at that level.
The 30V is the premium line equivalent to my 29B. The floorplan makes good use of the two smaller slideouts, but you do need to bring out the rear slide to use the drawer space in the bedroom.
