RoyB
Mar 15, 2016Explorer III
Those look like standard spade lugs as part of the heating coil in the printed circuit card.
Should pull right off with alittle pressure applied...
I wouldn't do alot of side ways pulling pressure as these lugs are just soldered in place to the circuit board...
Hopefully when you pull off the lug connections you will have enough wire length to cut off the connector and crimp on a new one... You should b able to find replacement spade connectors from any local auto parts store... Take the heating element with you to get the correct size connector...
If your assembly has the wiring to a removable plug then take the whole assembly to the local auto parts store and they can fix your cable and new connector plug for you at the store.
Sample board here shows what the spade lug looks like...
Roy Ken
Roy Ken
38,769 PostsLatest Activity: Apr 03, 2026
