ReadyToGo
May 19, 2014Explorer
I think as someone else suggested, get the mattress out and unscrew the board under the bed.
Since that is where the water tank is, that is where all the water connection and lines are.
Now backtrack a little.
What where you doing 12 hours before you found the wet spot?
Filling the tank? Using the water pump? Using city water? Taking a shower? Etc.
Once the bed and board is off, start using the lines and see if you have a leak somewhere especially on things you were using.
That is a fairly large water spot to be just a small leak. Plus the water has to come from somewhere. Up from the floor? Kind of unlikely.
From under the bed? Most likely and that makes a good place to start hence getting the bed and board out.
38,763 PostsLatest Activity: Dec 13, 2025
