- 4x4vanExplorer IIIThe A/C is not "needed" for the defrosters, but does improve the performance of them. A/C is called "air conditioner" rather than "cooler" because it "conditions" the air; it "drys" it out, which speeds up the defrosting action. However, your defrosters will still work without A/C, just not quite as quickly.
darsben wrote:
Mr.Mark wrote:
ferndaleflyer wrote:
Freon has nothing to do with the defrosters----defrosters run off of the heater and the only relationship to the a/c is they both use the same blower usually--but not always.
Just curious, then why does the air-condition compressor come on when using the defroster? (on cars)
MM.
The compressor is used to dehumidify the air for defrosting both my cars and my class A gasser.
But what do I know
Autos use the compressor. A Lot of Motorhomes also, but not all. What I found curious was his statement about 2 blower motors. UNLESS you have an overhead defroster system the SAME motor operates all the dash AC systems. The Motorhomes I have worked on, the same blower motor operates the Defroster and dash system. Some motorhomes(Newmar's and some Monaco's were 2 ) had an overhead blower system separate from the dash AC/defroster system, to help blow air DOWN from the overhead. Doug- darsbenExplorer II
MM.
But what do I know - Mr_Mark1Explorer
MM. - ferndaleflyerExplorer IIIFreon has nothing to do with the defrosters----defrosters run off of the heater and the only relationship to the a/c is they both use the same blower usually--but not always.
Twomed wrote:
Probably a switch cut in by the coach builder to cut off the compressor when heavy load (hill climbing). Helps keep your cooling system from overheating because a/c takes a lot of power.
The answer to leak is that it is under pressure whether turned on or not.
As mentioned above a good a/c shop can replace the switch for you. Be sure they are capable of saving the coolant (Freon or whatever is in your system) and recharge without having you pay for a full re charge, assuming it still gets cold.
This is one of those longer you wait the more it might cost things. Not crucial if you don't run the a/c, but could get expensive in a hurry if you do. :) :)
NO RV chassis(Gas or Diesel class A) has a system that cuts out the compressor under heavy engine load. The switch pictured is a Pressure switch and since it has 4 wires it does 2 things. IF the pressure drops(coolant leak) it cuts out the compressor, and it also activates the Condensor cooling fan. Doug- wa8yxmExplorer III
reddfox77 wrote:
So what is a binary switch for?
A binary switch is one that is either OFF or ON.
A Trinary switch has ON/OFF/ON but the two on's are different
And then life gets to be fun.. I have one switch with like 120 positions..Not sure centurduodeka perhaps I do not know.
(That's a lot of positions) - dakdaveExplorerMost of these switchs are can be changed without discharging system as they are on a schader valve. good luck dave
- GjacExplorer IIIWhat year and chassis is your MH? Is the cooling system an Evans? In the upper L/H top of your picture should be a black plastic box that should tell you the system?
- ScottGNomadYou don't want all the freon to leak out and stay that way. The damage will eventually get much more expensive regardless of use. I would get it fixed ASAP.
38,771 PostsLatest Activity: Apr 21, 2026
