kuziwk
Apr 14, 2016Explorer
kuziwk wrote:enblethen wrote:
The positive would normally pass through a battery disconnect relay.
The converter could be connected directly to the frame as well as the negative from the battery. The frame of the rig would act as the negative path rather then a wire.
Now that I think about it this is connected to what I thought was the battery isolator but I just googled a battery disconnect relay and sure enough I beleive that's where the positive from the charger and battery connect to. They are both on the same post of the relay...than the negative is on one of the other posts
This is the unit I have
http://www.google.ca/search?q=allanson+converter&prmd=niv&source=lnms&tbm=isch&sa=X&ved=0ahUKEwiO6_u9g4_MAhVW9mMKHTYmDOoQ_AUICCgC&biw=412&bih=603&dpr=3.5#imgrc=bW7t-lEX8OggaM%3A
This is why I need a 12 volt dc fuse board. Also in the picture it does not show the 120 volt breakers but they are on the left
38,778 PostsLatest Activity: Jun 10, 2026
