kuziwk
Apr 14, 2016Explorer
RoyB wrote:
Does your ceiling lights come on when you are not connected to shore power... Every one of those 12VDC connections I showed earlier haas to come from a ATC FUSE somemwhere. You must have a separate 12VDC fuse panel somewhere. I also don't see the circuit breaker as well. I bet they are in the same location the 12VDC fuse panel is located where ever that is...
You have to have one of those some where. Your RV is not that old...
SO you are saying those four FUSE HOPLDERs is all of your 12VDC Fuse protection???
Give us the model of your trailer I'd like to see this to haha...
If you have rewire for a modern 120VAC and 12VDC Power Distribution Panel it is going to take long... PD sells one of those as well which looks similar to the WFCO 8900 series I showed picture of above...
Roy Ken
Yeah it's a 1986 glendale sterling motorhome and I'm unable to locate any other fuse panel...there are 4 fuses on there that are 15 amp and there is a schedule on the panel that says air conditioner, fridge, lights and pump and what not. I would figure that all the lights are Daisy chained together. I can't imagine there being any other fuse panel as I've checked every panel or spot accessible. The picture does not show the 120 volt breakers but they are there and the there is a dedicated 15 amp for the converter which goes to.its transformer.
38,778 PostsLatest Activity: Jun 10, 2026
