Gary_
May 26, 2015Explorer II
Bucky1320, I have a 2000 Harney Coach 37' Riata and I don't know if this will help you but Monaco says my chassis is BLUE STREAK. The vehicle suspension is a Reyco Air System. It has 4 air bags, they are positioned behind each axle and under the frame rails. The air bags are attached to the axle with a support beam. The bags use air pressure to support the vehicle weight. Leveling valves control the amount of air pressure to the air bag. The leveling valve is responsible for maintaining ride height. Maintaining ride height is required for the air spring system to function effectively and is a critical part of the air ride system. REYCO FRONT SUSPENSION RIDE HEIGHT is measured from the top of the air bag to the bottom of the metal bell shaped area that comes out of the bottom of the air bag. It is 8 3/8 inches from top to bottom. THE REYCO REAR SUSPENSION RIDE HEIGHT is measured from the very top of the air bag where it contacts a frame rail to the bottom of the metal bottom of the bell shaped area that sits on the lower steel beam. It is 12 inches. Hope this might help. Gary
