wolfe10
May 27, 2015Explorer
Yes, out of spec ride height in the rear DOES put the U joints under a lot of stress and I have seen several cases where it has taken out the Allison output shaft bearings and seal. Remember, your drive shaft is only about 1.5' long. 2" out of spec is a huge change in drive line angle.
This isn't just about ride quality. You can break a lot of stuff with the suspension out of spec.
