time2roll
Jul 02, 2016Nomad
It is just ABS with almost no pressure. Mix some ABS shavings in with ABS glue should work. JB Weld should do fine also. If you think the crack may continue just drill a 1/8" hole at each end before you slap on the JB. Worst case you can cut the pipe out later.
38,769 PostsLatest Activity: Mar 31, 2026
