path1
Aug 08, 2014Explorer
Apparently some have a little hook at end of handle?
"Taken the Caliper Mounting Brackets off yet?" Tried but one is stuck big time. Got caliper slide pins out OK and one caliper mounting bolt. But the other one is stuck big time. I'm going to change the wheel bearings also, so it has to come off. If I was just doing brakes I would not mess with them. Have PB blaster soaking in it right now.
I was surprised how little of torque on spindle nut.
Going to give a few shots over weekend of BP blaster, then try again Monday. If all the parts come in, I'll give it a tug then. If it doesn't come loose, then I'll try some heat.
38,758 PostsLatest Activity: Nov 06, 2025
