wqnl463's avatar
wqnl463
Help with my inverter!
Ok so I have this class C and it is supposed to have a coach battery. There is even a tester for it, however, it seems to be missing. Along with the battery cables. The inverter/charger is a B-W Model 3230ul series 3200. It says everywhere online AND on the unit itself, that it works as inverter, and charger for coach battery. I cannot even find "cut-off" wiring as if someone took out the battery altogether. I have looked in every cupboard inside, and under the steps outside and all under the rig for the battery. Now to my question. If anyone has one of these 3230's could you tell me first, where are YOUR batteries/battery, and second, where are YOUR cables coming from on the unit itself. I can hook up a battery cable, I have electrical and automotive exp., but I want to do this right as to avoid and mishaps in the future, like electrical FIRES! Thank you
