SteadyEddy's avatar
SteadyEddy
Help with new wireless camera system
Hi all,
I have a 2014 Coachmen Mirada 35DL Motor Home that came equipped with a Furion camera system (rearview plus side cameras). this system is hardwired (not wireless).
I did not like the system for several reasons and purchased Haloview's RD7 wireless backup camera with left and right wireless side cameras and installed them. Everything installed fine and it all works fine. I have all three cameras on the LCD video screen at the same time (rear, left and right side). All cameras show full signal.
However, when I turn on the vehicle right turn signal, the right side wireless camera goes to "no signal". Other cameras are not affected. When I turn on the left turn signal, the left side wireless camera goes to "no signal". Other cameras are not affected.
I have completely disconnected the power to the Furion wired system, but this still keeps happening. I don't understand thy the respective left and ride wireless cameras go to "no signal" when I engage the vehicle turn signal. This is unacceptable since I need to be able to see the side camera image when the turn signal is on.
I am NOT using the trigger wire function for the RD7 unit. I am simply supplying power straight from 12v to the RD7 unit.
Any help  or assistance anyone can provide would be gratefully appreciated.
Thank you
  • Where did you get the supply power to both side Camera's? Did you use the original Furrion wiring for those Camera's? Did you run NEW 12 volt and Ground wires to the side Wireless Camera's? Doug
