hilldude's avatar
hilldude
Helwig sway bar
Installed sway bar today, not to bad. requires an 18mm and 15mm socket and 7/8 inch wrench for links on bar. Lots bigger than original 1 1/2 verses 1 1/8. The directions say when finished jump up and down on MH and listen for the bar hitting any thing at 155 lb I can't even shake it. Will try it out tomorrow. It was about $200 at Sd truck spring.
1 Reply
  • j-d's avatar
    j-d
    Explorer II
    You'll be pleased. I slid ours under the coach on top of the box it came in and that put me close enough to install without a helper. Bought front and rear from SD like many of us have. I wasn't the first one but was one of the earlier ones. They're easy to deal with and can actually answer questions.
