goufgators
Oct 14, 2016Explorer
Here I go again...
I seem to be full of questions for you readers to ponder. Here's my problem: on occasion, my 'jacks down' alarm will sound when driving. In each case, I hit the up button and it stops the alarm. I might drive another 50 or 100 miles before it sounds off again. I've never been in a position where I could pull off the road to see if, in fact, a jack(s) is partially down. So, I took it to an RV repair shop and after inspecting it, was told that all the hydraulic lines were leaking fluid. I had my doubts about that since there was no indication of oil leaks on the concrete pad where I park it and the reservoir never showed low on fluid. But, I didn't argue the point and let the mechanic go ahead with replacing all lines (thankfully, my service contract paid the almost $3K bill). I picked the RV up and on the way home (you guessed it) the alarm again sounded! I will be taking it back to the shop but would like your input regarding what you think might be causing the jacks down to alarm if, in fact, it is not caused by low fluid. Thanks! / Larry
