wolfe10
Jul 29, 2013Explorer
wallynm wrote:
I agree and you could change the equation by changing the carb jets based on altitude.nohurry wrote:
Skip, I always enjoy and respect your posts, but that 10% per 1000 ft can't be right can it? That would mean if a N/A engine was running at 7000 feet elevation, it would only have 30% of its power. I know there is some loss, but I have heard figures in the 3% per 1000ft range.
And, to a degree, modern fuel injected engines compensate for altitude by adjusting mixture-- the Oxygen sensor(s) input to the computer does this. It can keep mixture at the stoichiometric ratio.
It will NOT put more oxygen molecules in the air-- so power WILL be down at higher elevations since there are fewer molecules per cubic foot of air.
Just the same for people. It takes more breaths of air at 10,000' to supply your body than at sea level!
38,783 PostsLatest Activity: Sep 22, 2026
