roam1
Jul 29, 2013Explorer
skipnchar wrote:
With a normally aspirated engine (no turbo or super charger) you will be loosing something like 10% of your horse power for each thousand feet you go above sea level. If you have a turbo diesel or turbo charged gasser, this power loss is almost non existent. Also keep in mind that water (also coolant) will boil at a MUCH lower temperature at high altitude so you MAY have lost some water from your radiator. Check to be certain you have a GOOD radiator cap on your engine to keep the coolant under correct operating pressure.
More like 3% per1000 feet
38,783 PostsLatest Activity: Sep 22, 2026
