Gjac
May 02, 2020Explorer III
The one thing that rarely gets mentioned in the gas vs diesel debate is what size MH do you want. If you want a smaller size MH to travel to NP's,Sp's,or NFS CG's in the 30 -34 ft range I would look at something like the Tiffin Baystar. If you want something larger in the 37-42 ft range then look at a DP. Another thing to consider is performance on hills A 38-40 ft DP with 300 HP that weighs 30,000 lbs will not perform as well as a 30-34 ft gas MH with 362 HP that weighs 15,000 lbs. A gas chassis will have the sane eng in any length. A DP in general will have less HP in the shorter lengths. It is HP to weight ratio that will determine the performance. Every choice is a trade off and I think people in a 24 ft TT, TC or DP all enjoy their camping experience.
38,782 PostsLatest Activity: Aug 31, 2026
