Gjac
Aug 01, 2015Explorer III
High frequency on generator
I just changed my governor control board on my Kohler 5.5 KCM21 genset because the genset was running at max throttle. The new board fixed that problem and the genset engines idles down as it should. I went to try it with a load on but noticed that my old Magnetec battery charger which never charges above 13.3 v read 15.5 v. I read 120 vac in the outlet. I borrowed my friend's meter which measures HZ and volts. It just beeped and a fault light came on for HF( high frequency). I have three questions 1, Why does the battery charger read higher? 2, Can something other than the governor board cause this HF? The board is suppose to come from the factory preset, but it does have three pots that can be adjusted. 3, Or is this just normal and new boards need to be adjusted when first installed. I did turn off the circuit breakers for everything except the lights and converter before testing so hopefully there was no damage except my batteries being equalized.
