Smells bad. Parked in NW Arkansas humidity is in the mid 80s. Temp mid 80s. When I run the ac units to cool down it is pulling the gases from the vent tank into the coach. Never have had an issue lik...
Yes and yes on the cleaning the coils. But first pull the ceiling panel and find the four bolts that go up through the roof. Give each bolt about 1/4 to 1/2 turn.
The gasket and AC should not be tightened all the way down to the roof. There is supposed to be a gap that is just filled by the gasket. If you overtighten you will have a leak.
