wildmanbaker wrote:
Corkey05 wrote:
Your F53 has a hydroboost pump to assist braking. It doesn't have a vacuum system.
The hydroboost should work full time so you'll still have brakes if you should ever lose power (or ignition power fails). The idea is for you to have full braking power to stop no matter what.
Your probably hearing the boost pump running, as it will even under light peddle pressure.
Right on the button. This will concern new owners of ford chassis MH until they find out what it is and how it is designed to work.
Ya but that sound is not a hiss its more like a growl
