timmac
Sep 15, 2018Explorer
dougrainer wrote:timmac wrote:dougrainer wrote:
1. House Garbage disposals are 120 volt
2. House Garbage disposals are NOT a PUMP. They just chew up material.
Not true, I have a garbage disposal that I use to grind up my black waste and it pushed the waste thru a 1 inch hose 45 feet away into my cleanout at home, works every time..
Post the brand and model of the HOUSE GARBAGE DISPOSAL. I have replaced at least 4 in my lifetime and NONE have a pump in them. Besides, WHY use a House Disposal?????? What is the matter with the standard 12 VOLT RV Macerator?????
Its your typical 1/2 hp garbage disposal you can buy at lowes, and I did once buy a 12 volt Macerator pump that cost 3 times a garbage disposal that fail after using twice, also something that pushes water/waste 45 feet in a 1 inch hose does pretty good than for not being a pump unless you can answer where does my waste go and the hose does not go down hill its all level..
Just cause a garbage disposal is not your typical pump does not mean it cant pump/push water, and its NOT gravity fed because the waste/water wont go thru the hose unless the garbage disposal is running ??
