- rv2goExplorer II
rjxj wrote:
rv2go
Slick idea just dont forget the dishwasher knock out :0. I have looked at the $200 12 volt pumps, thanks for posting your set up. I like it.
Interesting website too. I put you in my favorites.
Not my site. Just interesting ideas. - rv2goExplorer II
mtofell1 wrote:
Just curious - how do you accomplish the required tight connection at the campground or dump station?
Take a end cap for 3" pvc pipe, cut a hole in it so a hose connector will fit, place into the sewer donut then place into the CG sewer. If your sewer donut is larger than 3", get a 4" cap. - azrvingExplorerrv2go
Interesting website too. I put you in my favorites. - mtofell1ExplorerJust curious - how do you accomplish the required tight connection at the campground or dump station?
- rv2goExplorer III use one. I modified this one to my own ideas.
RV Macerator Pump
The gray flow thru. Pump the black as needed. 75 feet thru a 3/4 inch hose. Works like a charm. No worry of overheating the 12 volt pumps.
38,771 PostsLatest Activity: Apr 15, 2026
