stugpanzer's avatar
stugpanzer
Homemade Leveling and Jack Pads
I made my own leveling and jack pads and I would like to show you all.
I did a lot of searching and read a bunch of reviews and saw what a lot of people have done here and other sites. I have a few more things I want to do to supplement this setup, but I sure do like how these work!
First of all, I have four of THESE Tri-Leveler Ramps that I carry. I have never had to use all four at once but do use them on occasion. One place I use them is when I visit my parents where they have a slope drive and I only have to put this on the driver side front tire. Here's a pic with my old coach:
I also have a set of THESE Jack Pads for my jacks but I never really liked them as they are too small but using them upside down has worked fine for me.
I am going to use Barn Stall Mats or Horse Stall Mats. I bought a Rubber Horse Mat at my local farm supply store. The bad art in that link does not do this thing justice. It is a solid piece of recycled tires made into a rubber mat that is 3/4" thick and is 6'x4' and weighs 100 lbs. I got the idea from THIS BLOG.
Now, in that article the guy cut his 8" x 12". I decided I wanted mine to be 12" x 12" so I measured and marked the mat for cutting:
Then I positioned the mat in between my truck bed and truck tailgate and used a saber saw to cut. This thing is heavy and trying to hang it over the edge like plywood does not work!
I now have 24 of these mats:
Finally I used a 3/4" paddle bit and drilled a hole in the center of each piece. This hole will be used with a tool that I am making to allow me to push them under the coach and out from under so I won't have to crawl under....with the exception of when I may need to stack them for the jacks. Those with manual awnings already have the tool with your awning rod.
The pads can be stair-step stacked to drive up on or they can be stacked on top of each other for under a jack/leveler.
I don't have pictures of them in action but I think they will do a fine job!
Thanks for reading!
  • Very nice! And since they're rubber, they'll be easier on the tires as well.
    When stacked, do they hold together or do they slip? I'm thinking if they're stacked, you might have to drill a couple holes in them and slip a dowel pin through to hold them in place. Once the rigs on em I would guess they wouldn't move, but driving up on them might.
    How much weight can they hold? I know I drove my diesel up on those plastic ones and they simply collapsed. These look like they would not.....Dennis
  • J-Rooster wrote:
    Thanks for the clicky of the pads! Make sure when you drive up onto the pads that your complete tire tread is on the pad. If not inner sidewall damage could occur.
    That is one of the reasons I wanted to make mine 12"x12" instead of 8"x12"!
  • Thanks for the clicky of the pads! Make sure when you drive up onto the pads that your complete tire tread is on the pad. If not inner sidewall damage could occur.
