atikovi's avatar
atikovi
Hood release cable frozen
On a 1988 Fleetwood Southwind. I removed the cable and can't get any movement from either end. The plastic cover looks fine. Trying to work some lube into the ends but not having any luck. Does anyone make a replacement cable?
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    There are places where you basically take a tape measure to your cable and report the length. they get one at least that long (may be longer) you may also need a "Cable stop" type thing You then cut to length (With the thign pulled out Put the cable in place and push in the handle. then slip the stop over the cable and tighten the screw.. Instant universal cable. if all else fails. NAPA
  • Check Amazon or take the old one to a car parts store. They should be able to find one that will work.
    There are tons of hood release cables available.
