Ken___Barbie's avatar
Ken___Barbie
Hood won't open
The hood on my Jayco Class C F450 does not open when the inside release lever is pulled. I'm on the road and any ideas would be appreciated. Thanks.
  • try this . one person pull and hold the release, the other beat down on the hood in the latch area ,even push down and release in that area.
  • On my "E" 350 had the same problem. Mine was caused by easing the hood down and not giving a good hard shove at the last moment to get the lock to fully seat. The cable or the latch in the grill wouldn't release. I had to take off the windshield wipers, that plastic panel under the wipers to get access to remove the hinge bolts completely removing the hood. Reset the hood latch and put everything back together. Just don't baby the hood when closing. If you have to go this route, operate your cable release before reassembly to make sure cable has not parted somewhere along its path.
