M_GO_BLUE1
Jul 01, 2014Explorer
rgatijnet1 wrote:
No need to fill the water tank but make sure that you input valve is set for shore water instead of fill water tank. Good luck!
You will need to fill up the water thank to check that the water pump is woking correctly...again make sure you knobs are in the corect position when using the water pump
38,705 PostsLatest Activity: Jan 14, 2025
