DiskDoctr
Jul 01, 2014Explorer
Bumpyroad wrote:Burwoods wrote:
We have a pressure regulator, the hoses of course, going to look for a by pass for the hot water tank to make sure it is open. Plug the MH in and hope the pump and water heater work, and we see nothing dripping anywhere. .
you don't want the bypass open, you want water filling up the heater tank, if you are going to see if it heats.
bumpy
I'll add....make sire the hot water tank is FULL before turning it on. If it has electric also, it will burn out the element quickly otherwise.
You can open the pop-off valve in the tank until water comes out to be sure.
38,708 PostsLatest Activity: Mar 04, 2025
