Many have posted about V10 heat on the passengers side. We purchased a V10 based MH and DW is experiencing the hot feet syndrome. Winnebago did a pretty good job with heat shielding under the mo...
Are you trying to save the carpet or are you going to replace is the question? I have not had the issue, but most adhesives can be softened with a heat gun and pulled apart. If the floor has gotten hot then it will have effected the adhesive and cause it to dry and stick a little more. You may have to cut the carpet out and then replace with some new stuff.
