- Tramp844ExplorerThink it might slide out enough to take water lines off ? Its a 1993 allegro bay 27' class c.
- Tramp844ExplorerSometimes it does ok. Sometimes it goes BANG when it lights. I just turned it on with no problem . it lights fine at first then when it tries to relight it happens,,sometime and sometime it lights just fine. Thay stuck this HW tank under the kitchen cabinet/sink area i have no clue how to get to the back side of the tank to take off water lines if i have to remove and replace it or to install the thermostat for the hot rod electric heating thing. No access pannel at all.
- HarvardExplorerWhen was the last time you tried to turn it on? Is this the first ever?
- Tramp844ExplorerOk. I'll clean the burner tube. If that does not help, whats next ?
- SoCalDesertRid1Explorer IIToo much propane is collecting before the igniter sparks it off. Like when you open the bbq grill valve and then the igniter won't light and then after a few tries it finally lights and BOOM! you get a big ball of fire in the bbq that singes your hair, if you happen to be looking over it when it goes off.
- donn0128Explorer IIBad air fuel mixture, or critters camped out in your burner tube. Start by cleaning the burner tube.
