2009 fleetwood providence have hot water with city water hook up but none with the 12 volt pump but do have cold with each and plenty of pressure with both
If you find the check valve to be the problem, I suggest you change it out to a single throw shut off valve. Those cheap check valves are a notorious problem. It has alwayed amazed me at what manufacturers won't do to save a buck.
