FIRE UP wrote:
Well Gang,
I'm a bit confused. The OP states his light in his water heater switch for "Propane" is not working and, has attempted to repair it. And, another poster has stated that "everyone has the same switch" so, I knew I had the same switch but, something was not "clicking" right in the brain when reading this and associating that switch with the propane side of the water heater.
You see, if you look at the picture below, it's of my "One Place Panel" (as it's called for Winnebago/Itasca owners), you'll see a red(lighted) switch in the upper left corner of the picture. But, also notice, that switch controls the "110VAC" side of the water heater, not the propane side. If you look just a bit below that switch, you'll see the water pump switch and, a PROPANE water heater switch. It, is not a lighted switch. There ARE, little LEDs below that propane water heater switch that indicate whether or not the water heater is functioning normal or, the pilot light is out. But, the switch itself is not illuminated.
So, we must have a different setup than the OP. No biggie, just wondering.
Scott
Yes, you do have a different set up. THAT is Winne's installed switches, not the W/H makers switches. That is why I asked for a pic. Tiffin used the W/H supplied switch panel. Doug
