thankdog wrote:
The water heater is Atwood GE 1b EXT - in general to clarify: the fluctuating temps only occur when using the pump b/c pump is constantly cycling on/off. (on city water pressure is constant). Every time the pump cycles off we get scalded then when it cycles back on we get a blast of freezing cold water until it normalizes to the temp we have set when turning on shower. *ETA* so this goes on for the entirety of the shower - hot, cold, on , off....Should the pump stay on during the shower when not on city water?
The fridge is a regular side by side GE like you would have in your house. I am looking for model etc.....
The pump pressure switch is bad or needs to be increased. Mine will constantly run but at a variable (speed) rate depending on the demand (how much water is required). This is clearly the problem for the water surging hot/cold.
Assume the GE did not come with the MH so I also would check the screen on the water line for the refg. I might be clogged restricting the water flow. If it did come with the MH I would check it anyway.
