ferndaleflyer wrote:
Coming home yesterday and everything powered by the house batteries stopped working---everything including things that just need 12 volts to keep them running like the frig. Batteries are less than a year old and read about 12.5 + checked with a load tester and all are good. I have current from the batteries at least to where the cable goes in the frame but don't know what to look for down line. This is a 1997 Winnebago Luxor DP. I have all the factory wiring diagrams but they aren't to clear to me. Any suggestions??????
ferdaleflyer,
Well, to start with, you're piloting a '97 era coach. And, a diesel pusher at that. So, that means, that in 1997, wiring and the way things were done, could quite possibly be, setup and designed, quite differently than the way it's done in '07 or '17. Now, with your automotive repair/diagnostic experience, you should be able to reason out, the path of juice, i.e. 12V from your house batteries, to all the appliances, lights, water pump etc. in your coach.
Fuses, relays and other control devices may have been implemented back then that are "dinosaur" ethics today or even just a few years back. I find this kind of stuff very interesting. It's fun to start at the batteries and then, progress on and on, 'till you arrive at all the 12V appliances. Yes, of course some times you can't follow certain lines and wires 'cause they disappear into walls, bulkheads and other AREA 51 enclosures.
But, they come out SOMEWHERE! Now, at present, you don't say what kind of operation you have. That is, many of todays Diesel pushers use the "Inverter/Charger" type system. That is, the Inverter side takes on the task of supplying 120VAC to the coach's outlets if and when called for.
But, the Charger side, is charged with supplying 12V BACK TO THE BATTERIES, mostly house batteries. Manufacturers, coaches, models, years, do it differently, with different apparatus. What does all this mean? Simply put, some coaches, i.e. diesel pushers, have and use the Inverter/charger system but, the charger side charges ONLY the house batteries while on shore power or gen power. Some charge both sets, house and chassis.
As for driving down the road, about 99.9999% of the coaches made, even back in the '80s, had the engine alternator charge BOTH SETS OF BATTERIES, while driving down the road. Very, VERY FEW didn't. So, at this point, you need to really get down and dirty and analyze what systems you have, for charging your batteries, both while on shore power and engine alternator.
Once you know what and how things work for charging your batteries, and what, if any, kind of relays, switches, solenoids, etc. that's involved with those charging systems, you'll then figure a pattern for analysis. Got power from here to here, good, move on. Check here, good, move on. Got power here, NOPE, hmmmmmm, go to work.
Scott
