catldog
Aug 09, 2018Explorer
msturtz wrote:
Hmm, is your AC one of the two-stage units? Is your rig a 50 AMP rig? It may be that you have one of the basement two stage AC units that on shore power use both to keep the rig at the setpoint temperature. However on generator power, since less power is available will only run one of the AC compressors. This means it would have less power available to run loads.
Our 93 Vectra was the other way around,when plugged into pedestal power only one compressor was powered,with the generator running both compressor were powered,the second stage power came directly from the
generators 20 amp breaker, I replaced the 30 amp cord and transfer switch with 50 amp and then both stages would run when plugged in.jg
38,763 PostsLatest Activity: Dec 05, 2025
