myrtle_beach_rv
Jun 06, 2014Explorer
Your allegro bay should have two 6v coach batteries located under 2nd step and a 12 v chassis batt under the hood. You can charge them by running generator for a couple hours. You have a 12 v disconnect switch located on a panel at the bottom of your cabinet on left side as you open the door to your coach. It will be your last of 5 switches in the panel. This be turned off when not using the coach. You can download the entire manual for your motorhome at the tiffin web site located under the owner info section.
