MrWizard
Nov 10, 2020Moderator
Your alternator is good, or your engine battery would be dead, check the battery disconnect switches, usually near the entry door, make sure the house/aux batteries are in the on/connected position, they should stay that way until you put the rv in storage
In disconnect mode very little will work, just like dead batteries, and they might not even charge from shore power.
I'm not familiar with the options for your rv
A whole house inverter powering an electric appliance will suck the house batteries dead,
Check to see if the water heater or fridge is set on for 120v, should be set for propane aka LP unless on Shore power
