RRodda's avatar
RRodda
house batteries OK?
Four 6 volt house batteries, topped with distilled water as needed, then plugged in RV overnight. Let is sit 2 days and got the following readings:
Voltages 6.25 to 6.31, set of 4 at 12.58
According to the Trojan chart that is 83 to 90% per battery and 87% for the bank.
Is a load test still needed? Should I take specific gravity readings?
Batteries are Interstate U2200 and are 5 years old, we dry camp extensively.
  • Hi Bob,
    Get a better SG unit, one with a float and with temperature compensation.
    That said the one battery sounds as if it is in trouble.
  • I have 2 cells in one 6V battery with poor SG (all balls don't float). This is after resting for a day. Batteries might be original (13 years old). I was planning to replace them in the fall . . . .
    Does the on-board charger (whatever Fleetwood provided in 2002) have an automatic equalization mode? Typically I DON'T leave the RV plugged to 120VAC.
    They do seem to hold charge longer if RV is left plugged in but I didn't want to overcharge them or run over the cord with the lawn mower . . . . .
    Should I plug in and forget?
    (checking water occasionally)
    Best,
    - bob
  • Hi,
    Charge them for another 2 days then let them sit for 12 hours before reading the voltages.
    A good temperature compensated specific gravity device is a much more reliable indication of state of charge than voltage.
  • Good idea to occasionally check SG-- that will tell you if you have a cell getting weak and would be a good indicator of when to EQUALIZE.
  • My 7 yr old Trojans read 6.39 after a recharge.
  • I wouldn't bother with those tests. Put a load on them and see how they do. 5 years is getting up there.
