FIRE_UP
Sep 15, 2015Explorer
prstlk wrote:
Once again I come to the best wisdom source to be found.
07 Holiday Rambler, 4 6v house batts, Magnum controller, Magnum inverter 2012.
Situation is, when we dry camp we run the gen for 2 hours when we stop, and another 1 hour in the morning. (might be more if we need the air)
Question is this. Should the house Batts not recharge from the engine alternator if we are driving from A to B for 300+ miles?
We have found looking at the control panel we are inverting going down the road.
Is there something we need to do different with the controller?
I find it hard to believe that after 300 mi we should arrive without fully charged house batts.
Thanks for all you do, you are all the best!
Well Sir,
First off, if your Magnum 2012 inverter is the same exact unit as we have, a Magnum 2012ME, it is an "INVERTER/CHARGER". And with that, that inverter/charger is basically a 4-stage battery charger. It normally uses three of those stages for normal charging.
1. Bulk Charging for massive amount of amps due to low battery voltage condition
2. Absorbsion Charging for mid-level charging as thing simmer down from the higher rate of, Bulk charging.
3. Float charging for when things are topped off and, your batteries are done with the heavy charging.
The "fourth" charging section is for EQUALIZING. That is rarely used and, based on your remote controller for that Magnum 2012, you have to MANUALLY setup the Equalizing stage.
Now, all of this primarily is for house batteries. Many coach builders, for some odd reason, other than they (the builders) were/are cheap, did not setup the coaches for chassis battery charging, from either shore power or, generator power. That task is mainly taken care of from the engines alternator. But, there are simple and semi-inexpensive remedies for this.
1. Trik-L-Start, a simple unit that normally runs around $35-$50, depending on where and when you buy it. IT is a little box that simply ties the charging system from your inverter/charger to your chassis batteries. It IS NOT A BATTERY CHARGER! It simply "DIVERTS" some of the battery charging intended for your house batteries, over to your chassis batteries, while being plugged into shore power or, generator power. However, that unit will only allow maximum of 5 amps to the chassis batteries.
2. Amp-L-Start, a bigger, more modern version of Trik-L-Start with much of the same function and setup.
3. A dedicated, 3-stage, battery charger, hard wired into your coaches electrical system, that's setup for charging ONLY the chassis batteries. I like and use this system because, it's totally isolated from the coach battery charging system. So, if anything should go wrong with the inverter/charger, your chassis batteries will still be on charge and get you out of your predicament.
This is a preference thing. Choose what suits you.
Now, as for your engine charging your house batteries while driving down the road. About 99.9999999999% of all coaches made, both in the past and, today, WILL charge both sets of batteries, while driving down the road, with the engines alternator. Now, just how it does it, for your particular coach/chassis, may and, quite possibly will be, different from other makes and models. Contrary to popular belief, THEY'RE NOT ALL THE SAME IN THIS SITUATION.
On many, you have what's called an Auxiliary Start Solenoid. That solenoid is used to link both the house batteries and, chassis batteries together for starting the main engine, should the chassis batteries be too low to crank the engine.
But, that solenoid has dual duty in many of the coaches. It will also, through the ignition wiring, tie the two sets together, and let the alternator do all the charging while your driving down the road. That solenoid will NOT CLOSE during normal cranking, unless you use your switch on the dash for "Auxiliary battery Start". (however its worded on your coach)
Now, basically, that's a mechanical link-up, between the two sets of batteries. There's NO THINKING of any electrical computer boards, circuit boards, BIRDS, or anything else. It simply closes AFTER the engine is started and, you are now sending alternator charging, through that solenoid, to your house batteries.
On other coaches/makes/model/engines/fuel types/ etc. there will be different systems that link the alternators charging to your house batteries. You will have to determine, just which system you have and, therefore be able to determine, if, you have a defective system or, component of that system.
So, to answer your question, should your 300 miles of driving, have charged your house batteries, YES! That is of course, if, your system, whichever one you have, is working properly. If it's not, then no.
One more thing. No, you should NOT BE INVERTING, while driving down the road unless, you have a need to. That is, if you're in need of 120VAC for some appliance, a residential fridge, a crock pot, (we've done that a few times for having a prepared meal at the end of a days drive), a TV or so for the little tykes in the back of the coach, etc.
But, if you're not in need of 120VAC while driving, NO your inverter does NOT NEED TO BE INVERTING. It has nothing to do with charging either set of batteries, while the main engine is running.
Scott
