Gene_in_NE
Dec 11, 2015Explorer III
ksg5000 wrote:Great advice above. I am presuming that you checked the battery acid level. It should be about 1/4" above the plates. :)
It's likely that's the original converter sold with the rig. As I recall they produce a constant 13.6 volts and are often referred to as "batter eaters" because they ten to boil off the battery water. Many people spend $150 and upgrade to something like http://www.amazon.com/Progressive-Dynamics-PD9245CV-Converter-Charge/dp/B000GANZZ6. Easy install with lots of "how to" on the web.
At any rate - you can test your existing converter by either measuring the voltage at the converter (best way) or measure it at the battery when the rig is connected to shore power ... should read around 13.6.
