gbopp
May 18, 2016Explorer
Why not just replace the battery with the same size? Unless it's not the original size that was installed at the factory, it should serve you well.
Check the voltage while the engine is running and/or on shore power. Maybe you're overcharging the battery?
Make sure the charging system is working properly.
Don't allow the battery to discharge too far.
If you want to upgrade, and have the space, consider two 6 volt golf cart batteries.
38,782 PostsLatest Activity: Sep 10, 2026
