dougrainer
May 18, 2016Nomad
Your Genset does NOT charge the batteries. Your Genset supplies the 120 volts to run the CHARGER for your batteries. If you have only a CONVERTER (you do since you have just 1- 24 series battery), then to fully charge a discharged battery that is below 50 percent discharged, it would take at least 4 to 8 hours(maybe more) to fully charge a 24 series battery. It all depends on what TYPE Converter you have and what its charger section is rated at. If you post what brand and model Power Converter, we can help you understand the charging parameters for that model. Doug
38,782 PostsLatest Activity: Sep 10, 2026
